Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Designing( Die manufacturing / Press die ) |
Auto parts assembly( Assembly/Inspection / Assembly ) |
General metal press die( Designing / Mold designing ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC milling ( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
3D modeling( Die manufacturing / Press die ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name | C-COM CO.,LTD. | Website URL | http://www.c-com.ne.jp |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 60,000,000 JPY | Employees | 270 |
Annual sales | 4,000,000,000 JPY | EMIDAS Member Number | 46642 |
Large | Medium | Small |
Designing | Mold designing | Casting die designing General metal press die NC data creation (press) |
Designing | Jig and tool designing | Welding jig designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Pipe bending Deburring Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC cylindrical grinding Gear grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing 3D modeling Drawing die Bending die Forming die Below 60 t 60 - 300 t Over 300 t |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing NC data creation |
Surface treatment | Printing and others | NC engraving |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly |
