Most recent update: 2002-02-05
Mass production jig manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Company name |
株式会社 川田製作所 (Kawataseisakusho) |
Website URL | http://www.kawata-ss.co.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 15,000,000 JPY | Employees | 25 |
Annual sales | Unregister | EMIDAS Member Number | 46636 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Jigs and tools |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Planer machining Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Ceramic Machining (resin) Keyway milling |
Development and production of prototype/Small-scale production | NC machining | NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Grinding processing | Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Plastic bonding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending |
Die manufacturing | Press die | Designing Manufacturing Blanking die Single press die Below 60 t |
Die manufacturing | Plastic mold | Designing Manufacturing Injection molding die Blow molding die Expansion molding die Vacuum/Air pressure molding die Extrusion molding die Below 60 t 60 - 300 t 000 t |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Compression molding die Blanking die Packing-related products |
Mass production | Plastic | Blow molding Vacuum molding Extrusion molding Insert molding Expansion molding Air pressure molding PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PEEK (polyetheretherketone) Fluororesin Thermoset resin FRP (fiber reinforced plastic) Elastomer Below 60 t 60 - 300 t 000 t Injection molding EP (epoxy) |
Mass production | Rubber | Rubber product prototype manufacturing Compression molding |
Surface treatment | Printing and others | NC engraving Engraving |
Parts manufacturing | Machinery part | Gear manufacturing Vacuum components manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing |
Parts manufacturing | Electric board and electronic part | Rigid board Protocol and small-scale (PCB) |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
Parts manufacturing | Other parts | Model manufacturing Sign board manufacturing |
