Manufacturing( Die manufacturing / Press die ) |
Designing( Die manufacturing / Press die ) |
Iron( Mass production / Metal press ) |
Stainless steel( Mass production / Metal press ) |
Welfare equipment manufacturing( Product manufacturing / Others ) |
Electrical machinery and apparatus manufacturing( Product manufacturing / Production property ) |
Medical equipment manufacturing( Product manufacturing / Medical equipment manufacturing ) |
Company name |
株式会社 羽生田製作所 (Hanyuudaseisakusho) |
Website URL | http://www.hanyuda-ss.co.jp |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 37,500,000 JPY | Employees | 100 |
Annual sales | Unregister | EMIDAS Member Number | 46534 |
Type of manufacturing | Home electrical appliances / Medical equipment / Stationery products |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Transfer press die designing General metal press die NC data creation (press) |
Designing | Product and part designing | Office equipment designing Medical equipment designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Simulation | 3D modeling Plating Press Cutting Welding Structure |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Stainless steel Aluminum alloy Router machining Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Deburring Coating Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Laser and turret punch press processing Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Robot welding Stud welding Projection welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing NC data creation Drawing die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Thickness Transfer press (80 - 200 t) Press robot (80 -200 t) Single press (below 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining Tapping machining Iron Stainless Aluminum alloy |
Mass production | Sheet-metal processing | Hairline processing |
Mass production | Blank cutting | Turret punch punching Laser and turret punch punching Fiber laser processing Clean cut Thick plate 6 mm or more stainless |
Mass production | Welding / welding | Projection welding CO2 welding Spot welding TIG welding (argon welding) Seam welding fixing with wax Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Parkerizing (phosphate film) Iron |
Surface treatment | Coating | Powder coating Electrostatic coating Melamine coating Acrylic coating Heat-resistant coating Metal coating |
Surface treatment | Printing and others | Silk screen printing |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly |
Assembly/Inspection | Inspection | Metal press Forging Rubber Measuring |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing Storage products |
Product manufacturing | Others | Welfare equipment manufacturing |
