Most recent update: 2023-12-08
Company name |
株式会社 産栄工業 (Sanneikougyou) |
Website URL | http://www.kksanei.co.jp |
Street address |
Shizuoka Japan
[See map] |
Person in charge | - |
Capital | 15,000,000 JPY | Employees | 97 |
Annual sales | Unregister | EMIDAS Member Number | 46464 |
Type of manufacturing | Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Progressive die Transfer press die Single press die 60 - 300 t Over 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Fine blanking Iron Stainless steel Aluminum Copper Brass Plated steel plate Thickness Thickness Transfer press (80 - 200 t) Transfer press (200 - 500 t) Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Assembly/Inspection | Assembly | Auto parts assembly |
Assembly/Inspection | Inspection | Measuring |
