Most recent update: 2007-12-07
Company name |
田中鉄工株式会社 (Tanakatekkou) |
Website URL | http://www.tanaka-t.com |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 14,000,000 JPY | Employees | 65 |
Annual sales | 800,000,000 JPY | EMIDAS Member Number | 46057 |
Type of manufacturing | Machine tools / Transportation equipment / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Gear hobber Thread-cutting Iron Stainless steel Aluminum alloy Titanium alloy Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC cylindrical grinding Plane grinding Cylindrical grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Arc welding Brazing |
Mass production | Forging | Hot forging Upsetter forging Iron Aluminum Over 5 kg |
Mass production | Casting | Cast-iron Ductile cast iron Cast steel 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Parkerizing (phosphate film) Black oxide finish |
Surface treatment | Heat treatment | Normalizing Annealing Stress relief annealing (SR treatment) Vacuum quenching High frequency quenching Carburized quenching Gas nitrocarburizing |
Surface treatment | Other surface treatment | Spraying Shot peening/WPC |
