Most recent update: 2022-01-31
Company name |
青谷工業 株式会社 (Aotanikougyou) |
Website URL | http://www.aotani-kogyo.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 31 |
Annual sales | 570,000,000 JPY | EMIDAS Member Number | 43688 |
Type of manufacturing | Medical equipment / Transportation equipment / Industrial machinery |
Large | Medium | Small |
Designing | Mold designing | General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Sheet metal protocol manufacturing Deburring Coating Mirror surface machining Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Shearing (longer than 121.2 m) CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing Mass production jig manufacturing |
Die manufacturing | Press die | Manufacturing Bending die Blanking die Shaving die Single press die Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Coining Iron Stainless steel Aluminum Copper Brass Plated steel plate Stainless steel material for spring Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Chromium (rack) Nickel chromium (rack) Parkerizing (phosphate film) |
Surface treatment | Coating | Air-spray coating Electrodeposition coating Electrostatic coating |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Heat treatment | Annealing Quenching Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Coating Buffing Shot blast |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Carrier machine manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
