Most recent update: 2014-10-12
Company name |
平森プレス製作所 (Hiramoripuresuseisakujo) |
Website URL | http://hiramoripress.web.fc2.com/hindex.htm |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 3 |
Annual sales | Unregister | EMIDAS Member Number | 43664 |
Type of manufacturing | Leisure goods / Telecommunication equipment / Electronic parts |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) General metal press die |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Angle machining |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Bending die Blanking die Progressive die Single press die Below 60 t |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Leaf spring die |
Mass production | Metal press | Bending Blanking Forming Iron Stainless steel Aluminum Copper Brass Phosphor bronze Stainless steel material for spring Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Progressive press (35 - 80 t) |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Compression coil spring Leaf spring Battery spring Spring washer Stainless steel Diameter |
