Most recent update: 2021-08-27
1954年に創業し、精密板金、プレス加工、金型設計製作の加工をさせていただいております。これからもお客様から信頼されるよう努力してまいります。
Company name |
株式会社 清富士 (Kiyofuji) |
Website URL | https://www.kiyofuji.co.jp |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 25 |
Annual sales | Unregister | EMIDAS Member Number | 39103 |
Type of manufacturing | Office automation equipment / Home electrical appliances / Telecommunication equipment |
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing Transfer press die designing General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | NC milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Precision sheet metal machining Sheet metal protocol manufacturing Deburring Coating Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Transfer press (below 80 t) Iron Stainless steel Aluminum Plated steel plate Thickness Thickness Press robot (below 80 t) Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Coating | Air-spray coating |
Assembly/Inspection | Assembly | Office equipment assembly |
