Most recent update: 2023-09-05
Machining( Mass production / Mechanical processing ) |
Complex turning machining( Mass production / Mechanical processing ) |
NC turning machining( Mass production / Mechanical processing ) |
Company name |
株式会社 飯塚製作所 (Iidukaseisakusho) |
Website URL | http://www.iizuka-i.co.jp/ |
Street address |
Yamagata Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 28 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 3625 |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Test | Specimen processing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Industrial machinery designing Energy-saving machinery designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Keyway milling Bench lathe machining Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Deburring Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Laser marking Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Arc welding Brazing Plastic bonding Other bonding methods |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Small-size prototype manufacturing Aluminum die-casting |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Micro-hole machining Iron Stainless Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Sintered metal Turning machining(plastic) Casting Titanium Fine particle material accepted |
Mass production | Plastic | PVC (polyvinyl chloride) PMMA (polymethyl methacrylate) Engineering plastic PEEK (polyetheretherketone) Fluororesin |
Surface treatment | Plating/Chemical conversion treatment | Acid pickling Degreasing |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Printing and others | NC engraving Engraving |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Industrial machinery assembly Toy and sundries assembly |
Assembly/Inspection | Repair | Industrial machinery repair |
Assembly/Inspection | Inspection | Measuring |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing |
