Also known as the Laser Processing Konbini, we have a wide range of products from one-off to large orders. We process iron, stainless steel, and non-ferrous metals in general. We also offer a wide range of services from cutting to welding.
Laser processing (longer than 121.2 m)( Development and production of prototype/Small-scale production / Blank cutting ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Handles 3D processing( Development and production of prototype/Small-scale production / NC machining ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
3D pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Nitrogen cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Chassis prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name | Insmetal Co., Ltd | Website URL | http://www.insmetal.co.jp/ |
Street address |
Urayasu-Shi Chiba Japan
[See map] |
Person in charge | Keiji Fukui |
Telephone number | +81-47-355-6511 | Fax number | +81-47-355-6516 |
Capital | 50,000,000 JPY | Employees | 135 |
Annual sales | 3,100,000,000 JPY | EMIDAS Member Number | 35938 |
Type of manufacturing | Heavy electric machinery / Industrial machinery / Construction material | ||
Main 3 products |
PR message
Our company name, 'Insmetal', is a compounded word of "Inspire" and "Metal".
In our logo, the red symbol mark represents new metal that has just come out of the furnace, and the thin line in the middle represents a racer light. Like this light, we always want to be a fresh company.
Laser cutting has become essential in the industrial field. The needs are becoming more sophisticated and diversified with the times. As we have a long experience in laser cutting and advanced technology, we can meet any customer's request.
By converting conventionally machined parts to laminated welded structural parts using laser welding, it is possible to shorten delivery times and reduce unit prices and the weight of parts. We have also introduced YAG laser welding in February 2011.
We sincerely look forward to your inquiry about laser welding.
Most recent update:2024-03-26
Large | Medium | Small |
Material | Steel component distribution | Pickled steel plate Heavy plate Stainless steel Shaped stainless steel Stainless steel spring Perforated metal Expanded metal Stainless steel pipe Hot-rolled steel plate Cold-rolled steel plate Electroplated steel plate Hot-dipped steel plate Colored steel plate Tin Chequered plate Tool steel Spring steel Shaped steel Flat steel plate Steel (round) bar Railroad track Seamless steel pipe Welded steel pipe Rectangular steel pipe Drawn steel pipe Deck plate Roof deck rolling |
Development and production of prototype/Small-scale production | Machining | Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel |
Development and production of prototype/Small-scale production | NC machining | Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing Sheet metal protocol manufacturing Pipe bending Deburring Mirror surface machining Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) 3D pipe machining Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
