Most recent update: 2023-09-15
Lost-wax ( Mass production / Casting ) |
Company name |
北陸ケーティシーツール 株式会社 (Hokurikuke-thishi-tsu-ru) |
Website URL | http://www.hktc.co.jp/ |
Street address |
Ishikawa Japan
[See map] |
Person in charge | - |
Capital | 57,000,000 JPY | Employees | 82 |
Annual sales | 800,000,000 JPY | EMIDAS Member Number | 35761 |
Type of manufacturing | Machine tools / Industrial machinery / Telecommunication equipment |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Casting die designing |
Designing | Jig and tool designing | General jig designing Mass production jig designing General-purpose jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Stainless steel Aluminum alloy Nickel alloy Molybdenum alloy Broaching |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Die manufacturing | Forging die | Hot forging die |
Die manufacturing | Casting die | Lost-wax casting die |
Mass production | Forging | Hot forging Iron Below 500 g 500 g - 5 kg |
Mass production | Casting | Lost-wax Cast steel Aluminum alloy Copper alloy 500 g and below Over 500 g and less than 5 kg |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Chromium (rack) Black chromium (rack) Zinc (rack) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Chemical conversion coating |
Surface treatment | Coating | Air-spray coating Electrostatic coating |
Surface treatment | Heat treatment | Annealing Quenching Air quenching High frequency quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Shot peening/WPC Buffing Shot blast Sound blast Glass beads blast |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Repair | Industrial machinery repair |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
