Most recent update: 2022-01-13
Multi forming( Mass production / Metal press ) |
Company name |
株式会社 西谷精巧舎 (Nishitaniseikousha) |
Website URL | http://www.nishitani-s.co.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 80 |
Annual sales | Unregister | EMIDAS Member Number | 3522 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Iron |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Forming die Multi forming die Progressive die |
Mass production | Metal press | Drawing Bending Blanking Multi forming Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Nickel Thickness Thickness Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Rhodium Electroless copper (barrel) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Electroless nickel (barrel) Electroless nickel (rack) |
Surface treatment | Coating | Electrodeposition coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Printing and others | Printing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Heat treatment | Vacuum annealing Vacuum quenching High frequency quenching Salt bath soft nitriding (tufftriding) Nitridation |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Vacuum deposition Other physical vapor deposition methods (PVD) Spattering Coating Carbide Dispersion/TD Shot peening/WPC Buffing Shot blast |
