Most recent update: 2022-08-26
プレス金型の設計、製作、試作~量産までプレス加工と一貫生産を行うプレス専門メーカー
Progressive die( Die manufacturing / Press die ) |
Designing( Die manufacturing / Press die ) |
Manufacturing( Die manufacturing / Press die ) |
Company name |
株式会社 大貫工業所 (Oonukikougyousho) |
Website URL | http://www.ohnuki.co.jp |
Street address |
Ibaraki Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 60 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 34417 |
Type of manufacturing | Industrial machinery / Electronic parts / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die Extrusion molding die designing 3D modeling (press) 3D modeling (plastic) NC data creation (press) NC data creation (plastic) |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | NC milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Robot welding YAG laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Forming die Shaving die Progressive die Transfer press die Single press die |
Mass production | Metal press | Drawing Bending Blanking Forming Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Assembly/Inspection | Assembly | Auto parts assembly |
Parts manufacturing | Spring | Terminal spring |
