Most recent update: 2023-11-03
・我ら「鉄の料理人 集団」
・全社員が国家技能士の資格を取得しています
・ステンレスの真空容器製造には、かなりの経験があります
・セミオーダー型の真空容器は、ネットからお問い合わせをいただき、好評です!
Vacuum components manufacturing( Parts manufacturing / Machinery part ) |
Company name |
赤田工業 株式会社 (Akadakougyou) |
Website URL | https://www.akada.jp/ |
Street address |
Nagano Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 46 |
Annual sales | Unregister | EMIDAS Member Number | 34412 |
Type of manufacturing | Measuring machinery / Industrial machinery / Medical equipment |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Broaching Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Water jet cutter machining CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Plastic bonding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Manufacturing |
Mass production | Rubber | Rubber product prototype manufacturing Blanking |
Mass production | Casting | Cast-iron Ductile cast iron Cast steel Aluminum alloy Copper alloy Zinc alloy |
Surface treatment | Coating | Air-spray coating Electrodeposition coating Electrostatic coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast Glass beads blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Industrial machinery repair |
Parts manufacturing | Machinery part | Gear manufacturing Vacuum components manufacturing Connection parts manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Measurement/testing devices manufacturing |
