Machining (horizontal)( Development and production of prototype/Small-scale production / NC machining ) |
Machine tool manufacturing( Product manufacturing / Production property ) |
Industrial robot manufacturing( Product manufacturing / Production property ) |
Casting( Mass production / Mechanical processing ) |
Complex turning machining( Mass production / Mechanical processing ) |
NC plane grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Plane grinding( Mass production / Grinding processing ) |
Company name |
岩本工業 株式会社 (Iwamotokougyou) |
Website URL | http://www.iwmt-kg.co.jp/ |
Street address |
Ishikawa Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 80 |
Annual sales | 1,000,000,000 JPY | EMIDAS Member Number | 34335 |
Type of manufacturing | Heavy electric machinery / Machine tools / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Iron Stainless steel Aluminum alloy Copper alloy Ceramic Machining (resin) Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining NC vertical lathe Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Cylindrical grinding |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Ceramic Automatic screw machining Air chuck equipment Turning machining(plastic) Casting Fine particle material accepted Urethane High precision High strength |
Mass production | Plastic | Urethane resin CFRP (carbon fiber reinforced plastic) |
Mass production | Grinding processing | NC plane grinding Plane grinding Cylindrical grinding |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Valve manufacturing Vacuum components manufacturing Optical parts manufacturing Shaft and roller manufacturing Mechanical parts |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Measurement/testing devices manufacturing Optical products manufacturing Vacuum equipment manufacturing Coating equipment manufacturing Industrial robot manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction machinery manufacturing |
