Most recent update: 2022-12-26
Company name |
十和田精密工業株式会社 秋田工場 (Towadaseimitsukougyou) |
Website URL | http://www.showa-gp.com/ |
Street address |
Akita Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 128 |
Annual sales | Unregister | EMIDAS Member Number | 34317 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Measuring machinery |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding Fiber welding Projection welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Chassis prototype manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking Shirring Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum |
Mass production | Metal press | Iron Stainless steel Aluminum Copper Brass Plated steel plate Stainless steel material for spring Transfer press (80 - 200 t) |
Mass production | Sheet-metal processing | Pipe processing Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Angle processing Deburring process Painting process Mirror surface material processing Hairline processing 3-roll machine Bender processing (flood control) Bender processing (servo) Can making (more than 5m) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Shirring Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum |
Mass production | Welding / welding | Projection welding Fiber welding Spot welding TIG welding (argon welding) Arc welding Robot welding fixing with wax Stud welding |
Surface treatment | Coating | Powder coating Melamine coating Urethane coating Acrylic coating Lacquer coating Heat-resistant coating Metal coating |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Surface treatment | Other surface treatment | Sound blast |
Assembly/Inspection | Assembly | Industrial machinery assembly |
