Most recent update: 2024-01-16
プロに応える先進技術 仕事は楽しく!人生も楽しく!
Precision sheet metal processing( Mass production / Sheet-metal processing ) |
Company name |
岡村機工 株式会社 (Okamurakikoukabushikigaisha) |
Website URL | https://www.okamura-kiko.com/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 80 |
Annual sales | 850,000,000 JPY | EMIDAS Member Number | 33500 |
Type of manufacturing | Measuring machinery / Electrical component for transportation equipment / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Deburring Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding YAG laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Sheet-metal processing | Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Deburring process Painting process Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Welding / welding | Projection welding CO2 welding Spot welding TIG welding (argon welding) YAG laser processing |
Product manufacturing | Medical equipment manufacturing | Dental products |
