Most recent update: 2022-05-02
Plastic protocol machining( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name |
株式会社 巧電社 (Kabushikikaishakoudennsha) |
Website URL | http://www.koden-sha.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 13 |
Annual sales | 500,000,000 JPY | EMIDAS Member Number | 33493 |
Type of manufacturing | Office automation equipment / Audio-video equipment / Home electrical appliances |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Magnesium alloy Machining (resin) Broaching Bench lathe machining Milling (resin) Lathe machining (resin) Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Jig grinding Thread grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Small-size prototype manufacturing Chassis prototype manufacturing Vacuum injection molding Fused Deposition Molding (FDM) |
Die manufacturing | Plastic mold | Manufacturing Injection molding die Below 60 t |
Surface treatment | Plating/Chemical conversion treatment | Plastic Black oxide finish Colored alumite |
Surface treatment | Coating | Air-spray coating Resin coating Flock coating Urethane coating Lacquer coating |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Printing and others | NC engraving Engraving Printing Silk screen printing Offset printing Silk (handles curved surface) Pad printing Hot stamping (gold embossing) |
Assembly/Inspection | Inspection | Plastic |
Parts manufacturing | Machinery part | Gear manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
