Precision sheet metal processing( Mass production / Sheet-metal processing ) |
Laser and turret punch punching( Mass production / Blank cutting ) |
Bender processing (servo)( Mass production / Sheet-metal processing ) |
Fiber welding( Mass production / Welding / welding ) |
TIG welding (argon welding)( Mass production / Welding / welding ) |
Spot welding( Mass production / Welding / welding ) |
Stud welding( Mass production / Welding / welding ) |
Company name |
株式会社 都留 (Tsuru) |
Website URL | http://www.tsuru.co.jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | 200,000,000 JPY | EMIDAS Member Number | 33483 |
Type of manufacturing | Industrial machinery / Kitchen / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Deburring Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing Nitrogen cutting Thin plate (below 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Projection welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Mass production | Mechanical processing | Tapping machining Iron Stainless |
Mass production | Sheet-metal processing | Kitchen equipment manufacturing NC set press Precision sheet metal processing Sheet metal prototype manufacturing Deburring process Painting process Mirror surface material processing Hairline processing 3-roll machine Bender processing (flood control) Bender processing (servo) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Turret punch punching Laser and turret punch punching Clean cut Thin plate 6 mm or less stainless |
Mass production | Welding / welding | Projection welding CO2 welding Fiber welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Surface treatment | Coating | Powder coating Melamine coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing |
Assembly/Inspection | Side job processing | Manual labor |
