Most recent update: 2017-09-20
Company name |
旭工業株式会社 花巻工場 (Asahikougyoukabushikikaishahanamakikoujou) |
Website URL | http://www.asahi-ind.co.jp/ |
Street address |
Iwate Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 20 |
Annual sales | Unregister | EMIDAS Member Number | 33462 |
Type of manufacturing | Medical equipment / Telecommunication equipment / Industrial machinery |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | Spinning Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Shearing (longer than 121.2 m) Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Chassis prototype manufacturing |
Mass production | Metal press | Drawing Bending Blanking Forming Thickness Thickness |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Acid pickling |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Other surface treatment | Teflon coating Buffing |
Parts manufacturing | Spring | Thin leaf spring |
