Most recent update: 2023-06-02
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
アークテック株式会社 (A-kutekku) |
Website URL | https://www.arktech.co.jp/ |
Street address |
Tochigi Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 38 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 3038 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing |
Designing | Jig and tool designing | General jig designing Automatic tool designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Shaper machining |
Development and production of prototype/Small-scale production | NC machining | NC lathe machining Boring milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Pipe bending 3-roll bending Bending (hydraulic) Bending (servo) 3D pipe machining Swaging Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic Other resins |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding Capacitator spot welding YAG laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Manufacturing Part processing Drawing die Bending die Blanking die Forming die Single press die 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Nickel Thickness Thickness Thickness Bulge forming die Single press (below 80 t) Single press (80 - 200 t) |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press Measuring |
Parts manufacturing | Spring | Thin leaf spring Leaf spring Stainless steel Diameter |
