Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Handles microfabrication( Development and production of prototype/Small-scale production / Machining ) |
Compression coil spring( Parts manufacturing / Spring ) |
Torsion spring( Parts manufacturing / Spring ) |
Formed wire spring( Parts manufacturing / Spring ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Double torsion spring( Parts manufacturing / Spring ) |
Tensil coil spring( Parts manufacturing / Spring ) |
Double-sided grinding( Mass production / Grinding processing ) |
Designing( Die manufacturing / Spring mold ) |
Company name | Sawane Spring Co.,Ltd. | Website URL | http://www.sawane.co.jp/eng/company/index.php |
Street address |
Hamamatsu-shi Shizuoka Japan
[See map] |
Person in charge | Takayoshi Sawane |
Telephone number | +81-53-447-3451 | Fax number | +81-53-448-8298 |
Capital | 30,000,000 JPY | Employees | 53 |
Annual sales | 860,000,000 JPY | EMIDAS Member Number | 3012 |
Main 3 products |
Primary clients |
PR message
Since founding in 1966, we have kept stable business and practiced " Think, Produce, Sell" by oneself. In our history of this powerful self-reliant progress, we have always been thinking five years ahead, establishing the right-sized enterprise, has established the system that leading-edge and wide range of needs.
As medium-sized spring manufacturer, not only we produce high quality products steady, but also we strive to provide solutions for problems by working together with our customers. We provide trial production, mass production to automobiles, electrical equipment and other industries. Moreover, we started concept-changing mail-order production for small lot orders. In 1993, we established a Japanese joint venture in China to provide products for Chinese market earlier than other Japanese and Chinese Joint Ventures of spring manufacturer did.
We have our own system for quality management, production management, and retail management aiming to satisfy our customers with our service.
Philosophy
Perpetuate our company
Gain adequate profits and keep the right scale of management, promote the idea of "Think, Produce, Sell" by oneself with our challenging spirits.
Cherish a life
Life is limited, only one time for each one of us. That is why we cherish their lives. Wish employees their good health and happiness, and we will make our company where they can feel joy and personal growth through their work.
Practice flexible management
Always predict what will happen in five years, put balanced and flexible management into practices.
Be a good company
Associate with good people and good customers to do the right business.
Always actively challenge works that other companies don't do or can't do.
Serve the community
Cherish the idea of "teach if taught, return favors if given", serve to people and the community, cooperate internationally.
Most recent update:2022-05-27
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Nickel alloy Handles microfabrication Titanium Handles microfabrication Brass |
Development and production of prototype/Small-scale production | Prototype processing | Bending Small-size prototype manufacturing |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die |
Mass production | Mechanical processing | Wire machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Titanium |
Mass production | Grinding processing | Magnetic Abrasive Double-sided grinding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Zinc (barrel) Zinc (rack) Parkerizing (phosphate film) Electroless nickel (barrel) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Black oxide finish Unichromate (white) Black chromate (black/green) |
Assembly/Inspection | Inspection | Spring Measuring |
Parts manufacturing | Spring | Terminal spring Compression coil spring Tensil coil spring Torsion spring Double torsion spring Shaped spring Battery spring Formed wire spring Spring washer Torsion spring Carbon steel Piano wire (carbon wire) Stainless steel Copper alloy Diameter Diameter Diameter |
