Most recent update: 2022-04-08
Aluminum( Mass production / Metal press ) |
Company name |
プロトエンジニアリング株式会社 (Purotoennjiniarinngu) |
Website URL | http://www.plot-engineering.co.jp |
Street address |
Mie Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 35 |
Annual sales | 700,000,000 JPY | EMIDAS Member Number | 29188 |
Type of manufacturing | Transportation equipment / Jigs and tools / Machine tools |
Large | Medium | Small |
Designing | Mold designing | General metal press die |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Titanium alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Sheet metal protocol manufacturing Pipe bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Water jet cutter machining CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Prototype/Small-lot molding prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining NC data creation 3D modeling Drawing die Bending die Blanking die Single press die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Plastic mold | Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Titanium Plated steel plate Nickel Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Bulge forming die Corson alloy Beryllium copper Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Single press (500 t and over) |
Mass production | Mechanical processing | Machining NC turning machining Wire machining Screw cutting machining Iron Aluminum alloy Automatic screw machining |
Mass production | Sheet-metal processing | Pipe processing Can-making Sheet metal prototype manufacturing Angle processing Pipe bender processing Deburring process Bender processing (flood control) Bender processing (servo) 3D pipe processing Swaging process Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Welding / welding | Projection welding CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Robot welding fixing with wax Stud welding |
Assembly/Inspection | Assembly | Office equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly |
Auto parts manufacturing | Body part | Door Grill Bumper Fender Door mirror Door lock Other body parts |
Auto parts manufacturing | Engine | Cooling system Muffler |
Auto parts manufacturing | Interior part | Seat parts |
