Most recent update: 2016-07-01
Five-face/axes machining( Mass production / Mechanical processing ) |
Company name |
株式会社ベル技研工業 (Berugikennkougyou) |
Website URL | http://www.beru.co.jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 12,000,000 JPY | Employees | 20 |
Annual sales | Unregister | EMIDAS Member Number | 29140 |
Type of manufacturing | Industrial machinery / Measuring machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Broaching Keyway milling Automatic lathe Honing Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Aluminum die-casting |
Die manufacturing | Casting die | Sand casting die Wooden model |
Mass production | Mechanical processing | Machining NC turning machining Five-face/axes machining Complex turning machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Automatic screw machining Turning machining(plastic) Titanium |
Mass production | Casting | Sand casting Aluminum alloy |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Iron Brass Aluminum Black oxide finish Colored alumite Hard alumite Black chromate (black/green) |
Surface treatment | Printing and others | NC engraving Engraving |
Surface treatment | Heat treatment | Annealing High frequency quenching Carburized quenching Nitridation |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Valve manufacturing Vacuum components manufacturing Connection parts manufacturing Optical parts manufacturing Shaft and roller manufacturing |
