Most recent update: 2023-08-24
Other industrial machinery manufacturing( Product manufacturing / Production property ) |
Company name |
ダイヤ精工 株式会社 (Daiyaseikou) |
Website URL | https://www.diaseiko.com |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 48,000,000 JPY | Employees | 85 |
Annual sales | 800,000,000 JPY | EMIDAS Member Number | 29085 |
Type of manufacturing | Industrial machinery / Construction material / Transportation equipment |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Gear hobber Thread-cutting Iron Stainless steel Aluminum alloy Sintered metal Broaching Keyway milling Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Air-conditioning equipment manufacturing Kitchen unit manufacturing Chassis manufacturing Pipe bending Mirror surface machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Thread grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Mass production | Metal press | Drawing Bending Blanking Forming Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Transfer press (80 - 200 t) Single press (below 80 t) Single press (80 - 200 t) |
Mass production | Forging | Cold forging Iron Below 500 g 500 g - 5 kg |
Surface treatment | Polishing/Lapping | Chemical polishing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Heat treatment | Annealing Full annealing Quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing Shot blast |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Other parts | Lock manufacturing Sign board manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Environmental equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing |
