Sand casting ( Mass production / Casting ) |
Gravity casting( Mass production / Casting ) |
Ceramic material( Material / Specialized material distribution ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC vertical lathe ( Development and production of prototype/Small-scale production / NC machining ) |
Wooden model( Die manufacturing / Casting die ) |
Company name |
株式会社 田島軽金属 (Tajimakeikinnzoku) |
Website URL | https://www.tac-casting.com/ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 60,000,000 JPY | Employees | 83 |
Annual sales | 2,000,000,000 JPY | EMIDAS Member Number | 26663 |
Type of manufacturing | Machine tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Designing | Test | Destructive test Nondestructive test |
Designing | Simulation | Thermal analysis |
Material | Specialized material distribution | Ceramic material |
Development and production of prototype/Small-scale production | Machining | Aluminum alloy Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC vertical lathe |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding |
Die manufacturing | Casting die | Manufacturing Wooden model |
Mass production | Casting | Low-pressure casting Gravity casting Sand casting Aluminum alloy 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Aluminum Colored alumite Hard alumite |
Surface treatment | Heat treatment | Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Quenching |
Surface treatment | Other surface treatment | Spraying |
