Most recent update: 2024-03-07
Chassis prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
General metal press die( Designing / Mold designing ) |
Company name |
有限会社 山下鈑金工業 (Yamashitabannkinnkougyou) |
Website URL | http://www.e-ybk.com/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 35 |
Annual sales | Unregister | EMIDAS Member Number | 26476 |
Type of manufacturing | Heavy electric machinery / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Drawing metal press die designing General metal press die 3D modeling (press) NC data creation (press) |
Designing | Jig and tool designing | Welding jig designing |
Designing | Industrial equipment designing | Carrier machine designing |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | Tapping Iron Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Deburring 3-roll bending Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Laser processing (longer than 121.2 m) CO2 laser machining Laser marking Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum 3D laser machining Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Prototype/Small-lot molding Simplified/Molding prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing 3D modeling Drawing die Bending die Forming die Single press die 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Forming Iron Stainless steel Aluminum Titanium Plated steel plate Thickness Thickness Bulge forming die |
Mass production | Sheet-metal processing | Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Deburring process Bender processing (flood control) Bender processing (servo) Bending process |
Mass production | Blank cutting | Laser marking Shirring Laser processing (over 1.2m) CO2 laser processing Clean cut Thick plate 6 mm or more stainless 3D laser |
Mass production | Welding / welding | Projection welding CO2 welding Spot welding TIG welding (argon welding) |
Assembly/Inspection | Assembly | Auto parts assembly Construction component assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press |
Product manufacturing | Others | Transportation equipment manufacturing |
