Most recent update: 2023-11-15
Drawing( Mass production / Metal press ) |
Company name |
株式会社 樋口製作所 (Higuchiseisakusho) |
Website URL | https://hig-jp.net/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 197 |
Annual sales | 9,000,000,000 JPY | EMIDAS Member Number | 26433 |
Type of manufacturing | Transportation equipment / Jigs and tools |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die 3D modeling (press) NC data creation (press) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Profile milling Iron |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Blank cutting | Thin plate (below 6 mm) |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Jig and tool manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining NC data creation 3D modeling Drawing die Bending die Blanking die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t Over 300 t Compound die |
Die manufacturing | Plastic mold | Insert molding die Below 60 t |
Mass production | Metal press | Drawing Bending Iron Aluminum Plated steel plate Thickness Thickness Bulge forming die Transfer press (80 - 200 t) Transfer press (200 - 500 t) Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) Progressive press (over 500 t) |
Mass production | Mechanical processing | Screw cutting machining Iron Automatic screw machining |
Surface treatment | Coating | Electrodeposition coating |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Auto parts assembly |
Assembly/Inspection | Inspection | Metal press |
