Most recent update: 2015-10-01
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 城東製作所 (Joutouseisakusho) |
Website URL | http://www.joto-sei.co.jp |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 20 |
Annual sales | Unregister | EMIDAS Member Number | 22527 |
Type of manufacturing | Industrial machinery / Transportation equipment / Telecommunication equipment |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Titanium alloy Nickel alloy Molybdenum alloy Keyway milling Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining |
Development and production of prototype/Small-scale production | Grinding processing | Cylindrical grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding Other bonding methods |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Small-size prototype manufacturing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Tin (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Chemical conversion coating Baking (hydrogen embrittling) Black oxide finish Colored alumite Unichromate (white) |
Surface treatment | Polishing/Lapping | Electropolishing Buffing |
Surface treatment | Heat treatment | Vacuum normalizing Annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Solution heat treatment Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Resin impregnation Teflon coating Buffing |
Parts manufacturing | Machinery part | Connection parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
