Progressive press (200 - 500 t)( Mass production / Metal press ) |
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Cold forging die( Die manufacturing / Forging die ) |
Thickness: 3.2 - 9.0 mm( Mass production / Metal press ) |
Fine blanking( Mass production / Metal press ) |
Shaving( Mass production / Metal press ) |
60 - 300 t( Die manufacturing / Press die ) |
Company name | Sato Metal Industry Co., Ltd. | Website URL | |
Street address |
Sakai City Osaka Japan
[See map] |
Person in charge | 佐藤隆幸 |
Telephone number | +81-72-227-7715 | Fax number | +81-72-227-7129 |
Capital | 20,000,000 JPY | Employees | 27 |
Annual sales | 500,000,000 JPY | EMIDAS Member Number | 22372 |
Type of manufacturing | Transportation equipment / Electrical component for transportation equipment | ||
Main 3 products |
PR message
As a manufacturer specializing in metal stamping, we have supplied parts to various industries such as automobile parts, bicycle parts, and various consumer parts. Utilizing the many years of know-how that we have designed and manufactured molds in-house since our establishment in 1948, we can produce from development, trial production to mass production. In recent years, in order to respond to further cost reduction and rationalization, we have challenged new construction methods and processing areas such as progressive cold forging by high-rigidity press and 3D molding by servo press as a method conversion from machining and casting.
In addition, we acquired ISO9002 in 2005 and will strive daily to improve quality and customer satisfaction.
Most recent update:2022-03-14
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Forming die Fine blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Over 300 t Compound die |
Die manufacturing | Forging die | Cold forging die Press forging die |
Mass production | Metal press | Bending Blanking Forming Fine blanking Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Combined press-joining Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Forging | Press forging Iron Others 500 g - 5 kg |
Surface treatment | Coating | Electrodeposition coating |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Vacuum quenching Austempering High frequency quenching Solution heat treatment Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing |
