Most recent update: 2001-11-30
Company name |
森尾プレス工業株式会社 (Moriopuresukougyou) |
Website URL | http://www.morio-p.co.jp/ |
Street address |
Fukuoka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 100 |
Annual sales | 2,000,000,000 JPY | EMIDAS Member Number | 22269 |
Type of manufacturing | Transportation equipment / Industrial machinery / Heavy electric machinery |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die 3D modeling (press) NC data creation (press) |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Profile milling Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Shaving die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Thickness Thickness Transfer press (80 - 200 t) Press robot (below 80 t) Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Printing and others | Engraving |
Assembly/Inspection | Assembly | Auto parts assembly Construction component assembly |
