Most recent update: 2017-09-29
Company name |
昭和精工 株式会社 (Shouwaseikou) |
Website URL | http://www.showaseiko.co.jp |
Street address |
Ishikawa Japan
[See map] |
Person in charge | - |
Capital | 385,000,000 JPY | Employees | 90 |
Annual sales | Unregister | EMIDAS Member Number | 22227 |
Type of manufacturing | Industrial machinery / Machine tools / Transportation equipment |
Large | Medium | Small |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Plant equipment designing Precision automatic machinery designing Industrial machinery designing Food industry machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Planer machining Plano miller machining Deep hole drilling Gear hobber Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling NC facing NC vertical lathe |
Development and production of prototype/Small-scale production | Electrical discharge machine | Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Sheet metal protocol manufacturing Angle machining |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Shearing Cutting Water jet cutter machining Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Mass production | Casting | Sand casting Cast-iron Ductile cast iron 500 g and below Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Coating | Air-spray coating Powder coating |
Surface treatment | Printing and others | NC engraving |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Industrial machinery assembly |
Parts manufacturing | Spring | Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring Conical spring Formed wire spring Volute spring Spring washer Torsion spring Carbon steel Piano wire (carbon wire) Stainless steel Copper alloy Diameter Diameter Diameter |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Food industry machinery manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing |
