Most recent update: 2022-06-28
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Fiber laser processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Etching( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name |
今泉工業株式会社 (Imaizumikougyoukabushikigaisha) |
Website URL | http://www.i-psm.co.jp |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 15,000,000 JPY | Employees | 36 |
Annual sales | 450,000,000 JPY | EMIDAS Member Number | 22168 |
Type of manufacturing | Measuring machinery / Industrial machinery / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing Corner shearing CO2 laser machining Laser marking Etching Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Stainless steel Copper/Aluminum Precision cutting Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding YAG laser machining Fiber welding Projection welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Chassis prototype manufacturing |
Mass production | Metal press | Bending Blanking Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Thickness Beryllium copper |
Mass production | Mechanical processing | Machining NC milling machining Tapping machining Rolling machining Screw cutting machining |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Other anti-rust treatments Degreasing Unichromate (white) |
Surface treatment | Coating | Powder coating Electrodeposition coating Electrostatic coating Melamine coating Urethane coating Acrylic coating Lacquer coating Transfer printing |
Surface treatment | Polishing/Lapping | Electropolishing Buffing Mirror polishing |
Surface treatment | Printing and others | Engraving Silk screen printing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Heat treatment | Quenching High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Spraying Buffing Shot blast Sound blast |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Optical products manufacturing Food industry machinery manufacturing Chemical industry machinery and equipment manufacturing Fluid equipment manufacturing Industrial robot manufacturing Information equipment manufacturing Monitoring device manufacturing Environmental equipment manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
Product manufacturing | Plant equipment manufacturing | Hydro/thermal/electric/atomic power generation apparatus manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Inspection and testing devices |
Product manufacturing | Food industry machinery manufacturing | Food manufacturing Other food industry machinery manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing Telecommunication equipment manufacturing |
