Most recent update: 2023-12-14
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Progressive die designing (light electrical)( Designing / Mold designing ) |
Manufacturing( Die manufacturing / Press die ) |
Company name |
株式会社 飯島精機 (Iijimaseiki) |
Website URL | https://www.iijimaseiki.jp/ |
Street address |
Nagano Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 22164 |
Type of manufacturing | Office automation equipment / Electronic parts / Electrical component for transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Copper alloy Keyway milling Bench lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Forging die | Cold forging die |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness Thickness Beryllium copper Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Leaf spring Conical spring Spring washer |
