Most recent update: 2018-05-18
Automatic machinery manufacturing( Designing / Industrial equipment designing ) |
Company name |
株式会社 酒井製作所 (Sakaiseisakusho) |
Website URL | http://www.sakaiwork.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 45 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 21343 |
Type of manufacturing | Industrial machinery / Measuring machinery / Machine tools |
Large | Medium | Small |
Designing | Product and part designing | Gear designing Pressure container designing Measurement/testing device designing External design |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Plant equipment designing Precision automatic machinery designing Industrial machinery designing Food industry machinery designing Energy-saving machinery designing |
Designing | Electrical planning | Electrical machinery and apparatus designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Keyway milling Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Chassis manufacturing Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch punching Shirring Cutting process Laser processing (over 1.2m) Shirring (more than 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Ultra-thin High precision |
Mass production | Forging | Header machining |
Mass production | Grinding processing | NC plane grinding |
Mass production | Sheet-metal processing | Pipe processing Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Angle processing Pipe bender processing Deburring process Painting process Bender processing (flood control) 3D pipe processing Can making (more than 5m) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Turret punch punching Shirring Cutting process Laser processing (over 1.2m) Shirring (more than 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) Submerged arc welding |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Nickel (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) |
Surface treatment | Coating | Air-spray coating Resin coating |
Surface treatment | Other surface treatment | Spraying Resin impregnation |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Valve manufacturing Vacuum components manufacturing Pressure container manufacturing Shaft and roller manufacturing Mechanical parts |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Vacuum equipment manufacturing Hydraulic pressure equipment manufacturing Food industry machinery manufacturing Fluid equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Marine vessel equipment manufacturing Hydro/thermal/electric/atomic power generation apparatus manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Inspection and testing devices |
Product manufacturing | Machinery and product manufacturing | Paper product manufacturing |
Product manufacturing | Food industry machinery manufacturing | Food manufacturing Other food industry machinery manufacturing |
Product manufacturing | Environmental equipment manufacturing | Recycling system manufacturing |
