Most recent update: 2023-06-21
Company name |
株式会社 恵那金属製作所 (Enakinnzokuseisakusho) |
Website URL | http://www.enakin.com/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 100,000,000 JPY | Employees | 135 |
Annual sales | 1,800,000,000 JPY | EMIDAS Member Number | 21090 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel Aluminum alloy Copper alloy Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining NC vertical lathe |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Coating 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Stud welding |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) |
Mass production | Forging | Header machining |
Mass production | Casting | Shell moulding Lost-wax Low-pressure casting Centrifugal casting Sand casting Cast-iron Ductile cast iron Cast steel Aluminum alloy |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Copper (barrel) Chromium (barrel) Chromate (general) Nickel (rack) Copper (rack) Gold/Silver plating Chromium (rack) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Chemical conversion coating Copper Zinc die-cast Aluminum Other anti-rust treatments Hard chromium (rack) |
Surface treatment | Coating | Powder coating Electrodeposition coating Electrostatic coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast Glass beads blast |
