Most recent update: 2024-01-05
CFRP (carbon fiber reinforced plastic)( Mass production / Plastic ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
GFRP (glass fiber reinforced plastic)( Mass production / Plastic ) |
Company name |
スピック 株式会社 (Supikku) |
Website URL | http://www.e-spic.co.jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 17 |
Annual sales | 350,000,000 JPY | EMIDAS Member Number | 20083 |
Type of manufacturing | Industrial machinery / Construction material / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Sintered metal Milling (resin) Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Cylindrical grinding Jig boring |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Drawing die Bending die Blanking die Progressive die Single press die Below 60 t 60 - 300 t |
Die manufacturing | Plastic mold | Manufacturing 60 - 300 t |
Mass production | Metal press | Drawing Bending Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Diameter φ0.6mm - φ9.0mm Transfer press (80 - 200 t) Single press (below 80 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Wire machining Micro-hole machining Electrical discharge machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Titanium alloy Nickel alloy Ceramic Sintered metal Turning machining(plastic) Titanium Fine particle material accepted |
Mass production | Plastic | GFRP (glass fiber reinforced plastic) CFRP (carbon fiber reinforced plastic) |
Surface treatment | Coating | Electrodeposition coating Electrostatic coating Urethane coating Acrylic coating Metal coating |
Assembly/Inspection | Assembly | Auto parts assembly |
