Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Turret punch press processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Coating( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Chassis manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name | Kobayashi Manufacture Co.,Ltd. | Website URL | https://team-kobayashi.com/ |
Street address |
Ishikawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 167 |
Annual sales | EMIDAS Member Number | 17942 | |
Type of manufacturing | Machine tools / Industrial machinery / Telecommunication equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Corner shearing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding Other bonding methods YAG laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Metal press | Bending Iron Stainless steel Aluminum Brass Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Coating | Air-spray coating Powder coating Melamine coating Urethane coating Lacquer coating Epoxy coating |
Assembly/Inspection | Assembly | Precision equipment assembly |
Product manufacturing | Production property | Energy-saving equipment/Automatic instrument manufacturing |
