Most recent update: 2018-02-21
Single press (80 - 200 t)( Mass production / Metal press ) |
Cold forging ( Mass production / Forging ) |
Drawing( Mass production / Metal press ) |
Company name |
株式会社 山本工場 (Yamamotokoujou) |
Website URL | http://yamamoto-kojo.com/ |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 15 |
Annual sales | 100,000,000 JPY | EMIDAS Member Number | 1396 |
Type of manufacturing | Office automation equipment / Home electrical appliances / Construction material |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding |
Mass production | Metal press | Drawing Bending Blanking Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Press robot (below 80 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) |
Mass production | Forging | Cold forging Iron Aluminum Brass Others Below 500 g 500 g - 5 kg |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
