Progressive die( Die manufacturing / Press die ) |
Progressive die designing (light electrical)( Designing / Mold designing ) |
Manufacturing( Die manufacturing / Press die ) |
Thickness: below 0.2 mm( Mass production / Metal press ) |
Thickness: 0.2 mm - 3.2mm( Mass production / Metal press ) |
Stainless steel( Parts manufacturing / Spring ) |
Phosphor bronze( Mass production / Metal press ) |
Brass( Mass production / Metal press ) |
Plated steel plate( Mass production / Metal press ) |
Progressive press (35 - 80 t)( Mass production / Metal press ) |
Company name | HSK Co.,Ltd. | Website URL | http://www.hskcoltd.co.jp/ |
Street address |
Ibaraki Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 45 |
Annual sales | Unregister | EMIDAS Member Number | 1302 |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die NC data creation (press) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Bending die Blanking die Progressive die Below 60 t Compound die |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Leaf spring die |
Mass production | Metal press | Bending Blanking Stainless steel Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Progressive press (35 - 80 t) |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Leaf spring Carbon steel Stainless steel Copper alloy |
