High-Flexibility Continuously Variable Transmission | Miki Pulley Thailand
Product Info
The PDC model is a belt-type continuously variable transmission that connects the motor and the driven shaft, making it ideal for applications requiring high design flexibility. This model features high efficiency, enabling seamless speed adjustments despite its simple structure. Additionally, its design significantly reduces maintenance effort, ensuring stable long-term operation.
Features
- Simple Structure: Its straightforward design makes it easy to handle.
- High-Efficiency Speed Adjustment: Allows for seamless speed adjustments, providing flexible settings tailored to various applications.
- Maintenance-Free: Guarantees stable long-term operation, significantly reducing maintenance effort.
- Design Flexibility: Supports a wide range of industrial applications with high design flexibility.
- High Reliability: Offers reliable performance due to high-quality materials and precise manufacturing.
Specifications
- Speed Adjustment Method: Belt-type continuously variable transmission
- Compatible Motor Output: 0.2kW to 2.2kW
- Dimensions: Compact design
- Material: High-durability alloy
- Mounting Method: Base mount system
- Operating Environment: Suitable for a wide range of temperatures
Applications
- Industrial Machinery: Speed control in automation lines and machining tools.
- Agricultural Machinery: Speed mechanisms in harvesters and tractors.
- Construction Machinery: Use in heavy equipment such as cranes and excavators.
- Transport Machinery: Efficient speed control in conveyor belts and transport systems.
The PDC model belt-type continuously variable transmission unit contributes to efficiency and precision improvements across various industries.
CONTACT
This is the inquiry form for MIKI PULLEY (THAI) CO., LTD.. Please enter your inquiry.
This service is intended to provide consultation and opinion requests for processing projects.
Please do not use this information for self-promotion or sales activities.
If we receive a complaint from a recipient about the contents of the transmission, we may take measures such as forcibly stopping the use of the service.
Inquiry Type*Required
Message*Required
Attach file
Only image (jpeg, jpg, gif, png, pdf) and compressed file (zip, lzh) extensions are valid. Maximum file size 10MB
