The V-TKM series heat treatment furnace is optimized for small-lot production and significantly reduces quality variations. We provide a clean and safe working environment without fire and smoke.
The V-TKM series heat treatment furnace is a cellular in-line heat treatment equipment provided by DOWA Thermotech. This series was designed to reduce quality variations by 65% and significantly improve production efficiency, especially in small batch production. The work environment can be kept safe and clean as it can be processed without producing smoke.
Features
Designed specifically for small-batch production to increase quality consistency.
Improve the safety of the working environment through clean processing that does not generate smoke.
Reduce processing lead time by 65% and achieve faster production cycles.
Significantly reduced non-working time from 12 hours a week to 1 hour a week, contributing to improved operating rates.
Cellular in-line design allows easy integration into production lines and supports flexible production systems.
specification
Series: V-TKM
Equipment type: Cellular in-line type
Processing capacity: Optimized for small lot production
Safety: Safety design without smoke
Efficiency: Significant reduction in processing lead time and downtime
Purpose
The V-TKM series is intended for use in a wide variety of fields, from automobile parts manufacturing to electronic parts and precision mechanical parts manufacturing. In particular, it maximizes its performance in small-lot production where quality consistency is required.
By introducing this heat treatment furnace, manufacturers can achieve both quality improvement and production efficiency, and build a flexible production system that can quickly respond to market fluctuations. The V-TKM series is the ideal choice for any manufacturing industry seeking a safe and efficient heat treatment solution.
Company name | DOWA Thermotech (Thailand) Co., Ltd. | EMIDAS Member Number | 93649 |
Country | Kingdom of Thailand | Street address |
T.Tasit,A.Pluakdaeng Rayong Kingdom of Thailand |
Telephone number | Log in to display | Fax number | Log in to display |
Employees | 270,000,000 THB | Annual sales | 333,000,000 THB |
Employees | 101 | Person in charge | Shigehoro Kono |
Type of manufacturing | Transportation equipment |
