Development and production of prototype/Small-scale production |
Machining |
General-purpose milling
General-purpose lathe machining
Straightening
Machining/Handles small-scale production (order from 1 piece)
Iron
Stainless steel
Aluminum alloy
Copper alloy
Machining (resin)
Simultaneous 5-axis machining
Milling (resin)
Casting
NC machining |
Machining (vertical)
Combined lathe machining
Handles 3D processing
Electrical discharge machine |
Wire electric discharge machining
Casting |
die-cast
Lost wax
Sand casting
cast iron
Cast steel
Aluminum alloy
500g or less
Mass production |
Mechanical processing |
Machining
Complex turning machining
Iron
Stainless
Aluminum alloy
Casting
High precision
Mass production |
Die-casting |
125 t or less
125 - 250 t
000 t
000 t
Aluminum
Zinc
Mass production |
Casting |
Lost-wax
Sand casting
Cast-iron
Cast steel
Aluminum alloy
Copper alloy
Zinc alloy
500 g and below
Over 500 g and less than 5 kg
5 kg and over
Aluminum bronze alloy
Mass production |
Grinding processing |
NC plane grinding
NC cylindrical grinding
Plane grinding
Form grinding
Cylindrical grinding
Jig grinding
Cylindrical mirror grinding
Internal grinding
Centerless grinding
Gear grinding
Double-sided grinding
Mass production |
Sheet-metal processing |
Can-making
Precision sheet metal processing
Housing manufacturing
Bending process
Surface treatment |
Plating/Chemical conversion treatment |
Nickel (barrel)
Zinc (barrel)
Chromate (general)
Alumite (anode oxidation)
Acid pickling
Electroless nickel (barrel)
Electroless nickel (rack)
Chemical conversion coating
Trivalent Chromate (barrel plating)
Iron
Copper
Brass
Zinc die-cast
Aluminum
Plastic
Other anti-rust treatments
Degreasing
Black oxide finish
Colored alumite
Hard alumite
Unichromate (white)
Black chromate (black/green)
Colored chromate (multi-color)
Gold(Hoop)
Electroless nickel (large)
Hard chrome (large)
Hard alumite (large)
Surface treatment |
Polishing/Lapping |
Electropolishing
Buffing
Mirror polishing
Surface treatment |
Heat treatment |
Normalizing
Quenching
Vacuum quenching
High frequency quenching
Carburized quenching
Nitridation
Surface treatment |
Barrel polishing |
Barrel finishing (vibration)
Barrel finishing (rotation)
Barrel finishing (centrifugal)
Surface treatment |
Other surface treatment |
Resin impregnation
Buffing
