Just apply heat for shape memory, the optimal solution for wire protection.
Overview
Heat shrink tubing is a shape-memory plastic tube that shrinks upon heating, conforming to a pre-set shape. Utilizing this characteristic, it is used for insulation, protection, waterproofing, moisture-proofing, corrosion prevention, and mechanical protection of various wires and components. Heat shrink tubing is ideal for internal wiring of electrical and electronic devices, automotive wiring protection, and even for protecting wires used outdoors, with its applications being extremely wide-ranging.
Features
High Insulation Performance: By covering connected or exposed parts of wires, it provides high insulation performance, reducing the risk of shorts and leakage.
Excellent Protection Function: The tube, once shrunk, protects wires and components from physical impacts, abrasion, and chemicals.
Easy Handling: It can be heated with easily available heat sources such as heat guns or lighters, requiring no special tools or skills.
Adaptability to Diverse Applications: Available in various sizes and colors, it can accommodate everything from thin wires to thick cables, allowing for the selection of the optimal item according to the purpose.
Specifications
Materials: You can choose from various materials suited to your application, including polyolefin, PTFE (fluoropolymer), and elastomers.
Size: Based on the pre- and post-shrink ratio (e.g., 2:1, 3:1), you can select the necessary size.
Heat Resistance: It's important to select within the range of heat resistance according to the usage environment.
Heat shrink tubing is widely used in various fields such as electrical work, manufacturing of electronic devices, and the automotive industry, due to its convenience and effective protection function. By selecting the correct size and appropriate material, it reliably protects wires and components under any environmental conditions.
https://nissei-ushiyama.co.th/common/img/home/product03.pdf
Company name | Nissei Ushiyama (Thailand) Co., Ltd. | EMIDAS Member Number | 92714 |
Country | Kingdom of Thailand | Street address |
Sriracha Chonburi Kingdom of Thailand |
Telephone number | +66-33-002-262 | Fax number | +66-33-002-272 |
Employees | 5,000,000 THB | Annual sales | |
Employees | 6 | Person in charge | Niina |
