► Air blast
[Air nozzle type]
This is a method of injecting projection material from a nozzle using the power of compressed air created by a compressor or something alike.
- It is suitable for blast processing in specific area by injecting a projection material from a nozzle.
- The projected material used is circulated by the suction force of the dust collector.
► Shot blast
[Centrifugal projection type]
This is a method in which an impeller called a blade is rotated at high speed by the power of a motor, and the projection material is projected by the centrifugal force.
- Since a large amount of projection material can be projected, it is possible to blast on a large area of a large product, or a large number of products, and it is highly efficient because many products can be processed at once.
- The used projection material is circulated in the bucket elevator.
► Deburring
It also removes fine burrs that cannot be removed by hand.
Very effective for products that dislike burrs, such as precision equipment and IT-related products.
► Cleaning
Efficiently removes surface stains such as rust, paint residue, and black shavings on the product.
Since it has a function to strengthen the adhesion of plating and painting, it is widely used as a pre-treatment process.
►Peening
Metal surface modification by surface hardening, increases strength and durability.
►Beauty
The brilliance of flowing grains increases the value of the product. It is also effective for erasing scratches.
It is also used for optical system parts to prevent diffused reflection of light.
► Surface roughness management
Metal surface modification by surface hardening increases strength and durability.
Company name | NAGANO HIDAKA (Thailand) Co., Ltd. | EMIDAS Member Number | 92627 |
Country | Kingdom of Thailand | Street address |
Amphur Bang Sao Thong Samut Prakan Kingdom of Thailand |
Telephone number | +66-66-2-182-5273 | Fax number | +66-66-2-182-5275 |
Employees | 2,000,000 THB | Annual sales | |
Employees | 8 | Person in charge | Kitazawa |
Primary clients |
