Company name |
ISHO VIETNAM () |
Website URL | |
Street address |
Binh Duong Socialist Republic of Vietnam
[See map] |
Person in charge | - |
Capital | 300,000,000 JPY | Employees | 50 |
Annual sales | Unregister | EMIDAS Member Number | 92133 |
Type of manufacturing | Office automation equipment / Electronic parts / Furniture |
Large | Medium | Small |
Designing | Product and part designing | Office equipment designing Model designing External design |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing General-purpose jig designing |
Designing | Simulation | 3D modeling Cutting Welding Structure |
Material | Steel component distribution | Heavy plate Stainless steel Shaped stainless steel Perforated metal Stainless steel pipe Hot-rolled steel plate Cold-rolled steel plate Hot-dipped steel plate Colored steel plate Other steel plates and straps Shaped steel Flat steel plate Steel (round) bar Other shaped steel bars Seamless steel pipe Rectangular steel pipe Steel castings Other steel pipes rolling |
Material | Specialized material distribution | Tin/Zinc based alloy |
Material | Nonferrous metal distribution | Titanium Aluminum extrusions |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Air-conditioning equipment manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Stud welding Other bonding methods |
Mass production | Sheet-metal processing | Can-making Air conditioning equipment manufacturing Precision sheet metal processing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Deburring process Painting process Mirror surface material processing Hairline processing 3-roll machine Bender processing (servo) Can making (more than 5m) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Nickel (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Nickel chromium (rack) Acid pickling Electroless nickel (barrel) Electroless nickel (rack) Iron Copper Aluminum Stainless steel Other anti-rust treatments Hard chromium (rack) Titanium Degreasing Black oxide finish Colored alumite Hot-dip galvanizing (small-size Nickel (hoop) solder(Hoop) Gold(Hoop) Electroless nickel (large) Black nickel Hard chrome (barrel) Hard chrome (large) Tin (hoop) |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrodeposition coating Electrostatic coating Aqueous coating Melamine coating Urethane coating Acrylic coating Epoxy coating Heat insulation coating Metal coating |
Surface treatment | Polishing/Lapping | Mirror polishing |
Surface treatment | Heat treatment | Normalizing Full annealing Quenching Vacuum quenching Flame quenching Nitridation |
Assembly/Inspection | Assembly | Office equipment assembly |
Assembly/Inspection | Repair | Office equipment repair |
Parts manufacturing | Machinery part | Mechanical parts |
Parts manufacturing | Electrical part | Other electrical part manufacturing Power-supply device manufacturing Transformer manufacturing |
Parts manufacturing | Other parts | Model manufacturing Sign board manufacturing |
Auto parts manufacturing | Body part | Door Fender Other body parts |
Product manufacturing | Production property | Machine tool manufacturing Energy-saving equipment/Automatic instrument manufacturing Food industry machinery manufacturing Coating equipment manufacturing Fluid equipment manufacturing Environmental equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing Interior and outer wall material manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Furniture/Interior | Nameplates Cabinetmaking Interior manufacturing |
