Most recent update: 2024-04-18
金属プレス加工をメインとし、後工程の請け負い可能。
組み立て、梱包部門もある為、完成品まで可能です。
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Company name |
株式会社 フサヤ (Fusaya) |
Website URL | https://y-fusaya.co.jp/ |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 36,000,000 JPY | Employees | 12 |
Annual sales | Unregister | EMIDAS Member Number | 91451 |
Large | Medium | Small |
Designing | Product and part designing | External design |
Designing | Test | Investigative research |
Development and production of prototype/Small-scale production | Machining | Tapping Iron Stainless steel Aluminum alloy Copper alloy Brass |
Development and production of prototype/Small-scale production | Sheet-metal processing | Mirror surface machining Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Prototype processing | Bending |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Brass Plated steel plate Stainless steel material for spring Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Tapping machining Iron Stainless Aluminum alloy Copper alloy Nickel alloy |
Mass production | Sheet-metal processing | Bender processing (flood control) Bending process |
Mass production | Blank cutting | Shirring stainless Copper / aluminum |
Surface treatment | Polishing/Lapping | Brush polishing Buffing Mirror polishing |
Assembly/Inspection | Assembly | Construction component assembly |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Spring | Compression coil spring Torsion spring Stainless steel |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing Interior and outer wall material manufacturing Lavatory products manufacturing |
