PR message
We, Tohoku Electronic Industrial CO., Ltd., engage in prototype production and semi mass-production, mainly using analog technology to manufacture products such as drivers used for lasers.
This product employs a high sensitive photomultiplier that can detect ultra-weak light emission in samples, and it is used as a tool for assessing the early stage of oxidative deterioration.
LSI miniaturization and high speed digitalization have improved rapidly in recent years.
Yet, it is difficult to convert all analog circuits into digital circuits, and it has also been said that designs with digital circuits alone can no longer guarantee the superiority of products. As a result, the role of analog technology is becoming more important.
We have acquired know-how and expertise over many years in analog technology, including areas such as manufacture of various types of power sources, and technology of laser drive control and temperature control. We also have extensive experience in digital technology, including areas such as integrated technology using CPUs and FPGAs as well as analog/digital I/Fs.
We employ technology, which has been developed as part of our R&D program, to integrate analog, digital, software, mechanical, and optical applications into various needs, such as new product development and design of order-made products.
Chemiluminescence Analyzer CLA-FS4
It is used to measure ultra-weak light emission from samples with high sensitivity and can detect the early stage of oxidative deterioration.
This standard model analyzer can also measure spectrum other than luminous intensities which provides possibility to be used for research in various field.
Chemiluminescence Analyzer CLA-ID3
This analyzer measures ultra-weak light emission from samples with high sensitivity and can detect the early stage of oxidative deterioration.
Luminance can also be measured.
Chemiluminescence Analyzer CLA-FL
This analyzer links with the HPLC system and can detect light emission with high sensitivity via the reaction between the sample and the reagent.
The analyzer has been used in a wide variety of application examples, such as measuring the fixed quantity of lipid peroxides (PCOOH) in the blood and measuring the density of the hydrogen peroxides in pure water.
Chemiluminescence Analyzer CLA-IMG
Equipped with an ultra-high sensitive CCD camera, this analyzer measures ultra-weak light emission from samples using an image with high sensitivity. It can detect the early stage of oxidative deterioration.
The analyzer can also measure deteriorating sections to visualize deteriorating situations.
Chemiluminescence Analyzer CLA-SP2
Using a highly sensitive CCD camera and diffraction grating, this analyzer can instantly measure the spectrum of weak light emission from the sample in high resolution.
Safe Driving Training System
This system is used in safety driving courses for vehicle operation.
The system lights up the signal lamp with different colors to indicate speed when a car passing between two points. In this way, the system can be used for car drivers to experience emergency stops and train risk avoidance capacity.
The course instructor can check approaching speed of test drivers and give appropriate instructions.
Q-SW Driver
This driver is used to drive the Q-SW for laser oscillation.
It is small and light-weight and can be easily integrated.
We can also customize your order according to your requirements.
RF Driver
This driver can be used for the laser generation frequency and as a generator for the laser module drive.
Digital modulation, analog modulation, FPS function and an internal/external control switch option are also available. We can customize your order according to your requirements.
Measurement/testing devices manufacturing( Product manufacturing / Production property ) |
Company name | Tohoku Electronic Industrial CO., Ltd. | Website URL | http://www.tei-c.com/english/index.html |
Street address |
Sendai city, Miyagi Prefecture Miyagi Japan
[See map] |
Person in charge | Tetsu Satou |
Telephone number | +81-22-356-6111 | Fax number | +81-22-356-6120 |
Capital | 60,000,000 JPY | Employees | 60 |
Annual sales | Unregister | EMIDAS Member Number | 88918 |
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Test | Chemical analysis Investigative research |
Product manufacturing | Production property | Measurement/testing devices manufacturing |
Product manufacturing | Medical equipment manufacturing | Inspection and testing devices |
