創業以来、主に切削加工を行っており、今ではマシニングセンターを利用したミーリング加工、特殊加工を行うことも可能です。当社の強みは“当社で可能なものであればなんでもご相談にのる!”という点です。
Company name |
村上製作所 有限会社 (Murakamiseisakusho) |
Website URL | http://www.murakami-seisaku.co.jp/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 20 |
Annual sales | 180,000,000 JPY | EMIDAS Member Number | 87892 |
Type of manufacturing | Industrial machinery / Home electrical appliances / Machine tools |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Straightening Iron Stainless steel Aluminum alloy Broaching Keyway milling Air chuck equipment Casting Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 3D processing |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Aluminum die-casting |
Mass production | Mechanical processing | NC milling machining NC turning machining Tapping machining Screw cutting machining Iron Stainless Aluminum alloy Broaching machining Air chuck equipment Turning machining(plastic) Casting |
Surface treatment | Plating/Chemical conversion treatment | Electroless nickel (rack) Iron Black oxide finish |
Assembly/Inspection | Inspection | Measuring |
