Auto electrical parts
Manufacturing facilities
You can get very precise core pins for pipe molding.(The sample in pic :OD:φ0.4mm± ID:φ0.2±0.01)
The sample is made of pre-hardened stainless steel, and the outer and inner diameter of the tip core can be customized as you like.
Although it has a very small and thin tip core, the machining is completed only by turning and cutteing (without using the grinding process), which means you can save the cost for purchase.
Company name | Plus Engineering Co., Ltd. | EMIDAS Member Number | 87307 |
Shibata-gun Miyagi Japan |
Telephone number | Log in to display | Fax number | Log in to display |
Employees | 60,000,000 JPY | Annual sales | |
Employees | 106 | Person in charge | ASANO Ken-ichiro |
Type of manufacturing | Jigs and tools / Industrial machinery / Electronic parts |
